lithium
lithium's build- 3way +sub
car- 00 olds intrigue
equipment
-deadening
-raammat all over the fucking place.. afew layers in the doors and 1 in the trunk (along with some dynamat extreme) :Doh:
-mlv and cc foam from sds (didnt read about SDS till after the raammat install.. :( )
-source
-clarion dxz 785usb
-amps
-kicker
-kx250.2 mids
-kx250.2 midbass
-zx100.2 tweets
-kenwood
-kac x10d ~150 watts @ 8 ohms to sub
-speakers
-tweeter
-dayton nd20
-mid
-tang band w4 1337sd
-midbass
-peerless sls 8"
-sub
-mach 5 mj 18 (old style) 8 ohm
-wiring
-knukoncepts rca
-1 run kicker 4 gauge
-1 run stinger 4 gauge (got it for free)
-14 gauge speaker wire
-some other random distro's and 8 gauge mixed in...
so i already made the molds of the kicks a month or so back. after that i tried to sculp the mids out of expandable foam.... decided it wasnt working out right for the passenger side and gave up. here are few pics of the passenger side.
passenger side build - nothing fg'd yet, just aimed and grill cloth stretched over
here is the driver side.
having to deal with the ebrake pedal was a bit annoying..
i also tried to sculp this side out of foam.. turned out to be a waste of money.. but whatever
0103010118a.jpg0103010118c.jpg0103010119.jpg0104010110.jpg0104010126a.jpg0104010126b.jpg0104010126.jpg
this is how i did the aiming.. pretty scientific instruments here! lmao
some other tools
ordered plenty of grill cloth!
pic of both
0 gauge to do a new ground.. right now its pretty ghetto
also my 50 foot roll of speaker wire.. already have 2 runs in the car but this stuff is so cheap why not pick a bunch up. almost ordered the 100 ft roll :)
my section of the garage... dad doesn't give me much space :(
my old peerless 3" fullranger (you can see the stacks of cds i picked up for xmas...)
panoramic shot of the computer monitors. ssa ftw!
(23" and 2 17", and another 19 not seen)
adding some output to this lighter!
mj 18 next to my AA arsenal 12
messed around with the 12 for afew weeks. the mj is going back in though
tang band w4, sexy as hell! actually this is the only one i have while the other is on back order till the 11th of jan.
lil dayton nd20 :)
my xmas in a partsexpress box
alittle backround on the mj18, i put it together myself after getting the motor from a member here and ordered the basket and recone from mach 5
some pics of how its installed
pics of the amps installed. actually doesn't show the 4th amp, i got it later and i think ill be redoing the amp rack later on..
amps upside down under false floor
sls 8's in the doors
zero cutting hehe
trunk is deadened.. doors have it coveredddd (ya im an idiot with a million layers). also have mlv and CC foam in the doors :woot:
open to any advice, thoughts, comments, etc. sorry about the shitty cell phone pics :(
i think i need to change the shape of the lower portion of the passenger side kick so it matched the driver side.
ill get better pics up of both of them in my car to give you guys a better idea of how they look.
Why didn't you relocate your emergency brake?
Good job keeping your wiring tidy.
real nice setup mang... looks great!
Looking good !
How big are the kickspods ? Do they vent somewhere ?
honestly i have no idea how to relocate it besides completely removing it.
its still functional with the pod installed
the wiring its pretty ugly now that i added the 2nd kx250.2 but i plan to mount it overtop of the other one and add some fans for cooling. hopefully i have enough depth... otherwise ill have to come up with something or redo the entire amp rack :(
Looking good !
thanks, not sure on the size. currently they will be sealed. if that doesn't work out ill try aperiodic into the carpet. and if that fails ill cut some carpet and vent it out.
actually if i decide to cut some carpet ill just redo the pods. there is at least 3 inches of carpet and foam before you get to metal in the kicks.. i could probably fit the driver side pod behind the e brake and not interfere with it
Making me jealous
thanks!
