tuckin-nuts
97-03 f 150 buildsanyone
amyone got some pics of a walled off 150 ...i wand to get 2 fi 18's or mabe 4 if they would fit ...now sure what way i should build the box...so i need some ideas to go off of
also whos better fi or re ...or are they about the same ....
I would personally buy Fi over RE.
Post '05 RE is inferior to Fi. Pre '05 is on the level of Fi.
ok thanks ..also could someone move this im going to use this for all my questions since this will be my 1st spl build ..when i get to building my box with the port whats best in the middle firing between the seat or up high over the seats ...i also wish my truck didnt have the 3rd doors when i only had to rf hx2 the flexed bad so when i get the new build up they are going to fall off ..also i can find a kit to run more the one alt on my truck "its a 99 f150 5.4" ..also if i get fi i was looking at the ssd and q line they are more in my range ...and have no idea on what amp/amps i will run ...i plan to get a tool box to run all the batts in ..
15"s are your best bet.
Knew that one was coming ;)
Kid slow down. Take a breath. Use proper puncuation and capitalization. You end a sentance with a period, not three.
Also, Can the RE idea. They have gone to shit. If Fi and Re are the only two you want then go Fi and never look back.
J
Make sure to address the electrical first and foremost when planning a high powered wall.
My personal preference is Sundown and Incriminator! But Fi over RE.
:morepower1:
