bimmerboy
Quote for 15" Q
Hey Andrew,
your 1st box is holding up great... Just not hitting the lows as hard as I wanted, mainly due to me keeping the box pretty small for a 15... I wanna go BIG this time, with as much volume and port area as possible !
Could you quote me on a new box?
- Max dimensions are 34"Width x 18"Height x 20" Depth
- I want to get 4 cubes if possible with 16-18 sq.in. of port area, 30hz
- Sub/port back, no carpet, double baffle, regular port.
Sub Info:
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
Take your time, and thanks in advance!
Edited by bimmerboy
a little less than 3cubes since the box design was orig. for a SSD but then a changed my mind and got the Q which has more sub displacement....
Ahhh that's right! I forgot why it was low for a Q. I will get a design going and get a price for you.
Andrew
Ok, I was able to fit 3.75 cubes with 57.75 sq inches of port.
I used your max dimensions of:
18 tall
20 deep
34 wide
I am indenting the sides 3/8th of an inch, if you would like no indent I can try and get closer to 4 cubes.
This enclosure will cost: $148.75 plus shipping. This price includes the 15% off.
Andrew
you should be hella happy with a larger, lower tuned box.
i went from 3 cubes at 33hz to 4 cubes at 31hz, and boy does it make a difference!
:drink40:
18 tall
20 deep
34 wide
Andrew
OK I need to sell my old box before I get the new one... Will keep you informed. Thanks for the info.
