Well people I am debating to whether to keep my Arc Audio amps installed or take my Zapco DC amps out of the closet and swap the Arc Audio for the Zapco DC. If you were doing the SQ build which one would you do?
Thank you
Ebrahim
if i was you i would use zapco just because of the name plus i am running a 2-pairs of there comps and they are amazing plus i used to use a smaller zapco amp back in the day and it was doing me pretty well!
but now i am spl lol sq is so quite but it sure sounds pretty lol!
The level of control of the Zapco's win out in my book. :)
If you are just using them as gain blocks then it is a moot point as either will be more than fine to solve your needs.
I would use the Zapco DC's for the enhanced processing capabilities.
Unless you aren't planning on using the DC's processing......in which case I'd use which ever has the most power.
I should of mention I am planning to run my Morel Dotech Ovation 6 active which is a two way but going three way active in the middle of next year.
Also I have an Eclipse CD 5030 head unit installed that I am going to use and I am selling my Diamond Audio D3 and replacing it with a SSD12 or SSD15 from Fi Audio.
Thank you
Ebrahim
If you have no other processing than the DC's should be a no-brainer.
Exactlly
