orlandoman
SOUND QUALITY / SHOW OFF SYSTEM
Okay I am looking for some help in this forum because I am loosing hair over this. I currently have a system in my ride and it is progress though.
Eclipse CD 5030
ARC AUDIO KS 300.2
MOREL DOTECH OVATION 6
ARC AUDIO KS 500.1 MINI
DIAMOND AUDIO D3 15
Now first things first the KS 300.2 is powering the components at 180 x 2 @ 4 ohms
The KS 500.1 Mini [500 x 1 @ 2 ohm] is powering the Diamond Audio D3 15 [1.75 sealed enclosure].
Anyways looking to swap out the Diamond Audio D3 for a Fi Audio sub most likely the SSD 15. I was told to get a single dual 1 ohm sub and wire it in series to make it a 2 ohm sub. Anyways I have a pair of Selenium 6 Midwoofers that are 8 ohm and most likely go three way up front or go crazy with something different. Does anyone know if the SSD would be able to handle 500 watts without dying on me?
Has anyone tried the Fi Audio IB subwoofers as midbass or even on the rear deck?
I know it is a tall order and I am sorry.
Thank you
Ebrahim
The SSD only comes in Dual 1 ohm or Dual 2 ohm coils.
For dual 1 you can wire to .5 ohm (not recommended for daily) or 2 ohm.
For dual 2 you can wire to 1 ohm or 4 ohm.
The SSD will do perfectly fine on 500 watts, as long as the person behind the knobs knows what he/she is doing.
Since your amp does the 500 at 2 ohm then you should get the Dual 1 ohm option.
I moved your repeat thread.
