edouble101
XCON 15D2 in a sealed Khaotik or XCON 12D2 ported?
I want to run a Sundown SAZ1500D v.2 and a XCON 15D2. I have a 2008 Hyundai Elantra and unfortunately a 15" ported Khaotik enclosure will not fit. So my question is : do I buy a 15" sealed Khaotik enclosure or a 12" ported Khaotik enclosure? Which of the two will give me the most output when powered by a SAZ1500D v.2?
Thanks!
I would go 12" Xcon ported or try to build your own box, you should be able to fit a 15" ported enclosure in your trunk. Go do some measuring and someone should help you with a design. If not then a 12" will still be feasible.
You should just have a custom box built that will fit your trunk for the 15 imo. Single 15 ported is one of my favorite setups to run. It's nice to hit 143+ with a single sub. Check out one of the box builders on the forum, someone might even be in your are. Glwtb.
Ported, hands down :)
Most output would be ported.
No doubt. I didnt know if a 12" ported would be more output than a 15" sealed though.
Thanks for the reply.
My dilemma is that my trunk is fairly large but the opening isnt. A 15" ported enclosure will fit in there just fine, it is getting the enclosure in the trunk that is the issue.
And that my friend is why I said ported!
Because a ported 12 in will most likely have more output than a 15 in sealed thus my answer was ported.
If you build the ported enclosure correctly, you will be surprised at the power of a port.
I am seeing if Argent Audio can build me something special :fing34: Hopefully he has a design in mind for the XCON 15D2 that will squeeze in my trunk.
Tell Argent to build abox with aeroports. It will be smaller than a box with a slot port.
the trunk of my car is small, it was tight to fit a 3.5 ft3 slot ported box, but with 2 4" aeroports, I easily fit a 3.1 ft3 box in it, with a 15" Xcon.
And I love it. It is much much more powerful and louder than the same xcon in a 3 ft sealed box.
Argent Audio designed an enclosure for me :drink40:
