gentlejax
minilith install clarifications please , I am a little confused
looking at this in my head....I have 2 rca outputs for sub off deck....so do I need to run "Y" splitters off them into inputs 1-4 ? I think that is how I am supposed to do it. cant see what else there would be to do.
I got the rca part figured out. I ran a Y splitter from my left /right sub rca to the mono input of the amp...
but now I am confused about the response on wiring the sub. its a dual 2 ohm sub
here is what he told me. first part makes sense ...2nd part doesnt...
I have the sub wired for a 4ohm load now and its wired bridged at the amp...the amp has 2 sets of terminals for dual coils or 2 subs..
Dear Michael,
The dual 2 ohm coils can be wired in series = 4 ohm and
connected to the amplifier (200w of power) OR you can parallel
the coils for 2 ohm and again connect to the amplifier (400w)
The manual can be downloaded on our website
---------- Original Message ----------------------------------
Date: Tue, 19 Oct 2010 11:01:26 -0700 (PDT)
>Mr. Mantz
>I finally got the mini in and I want to make sure its hooked up
correctly.
>I have left/right RCA sub outs from the deck. I use a Y
splitter and join the signal and run it into the mono jack on
the amp. yes?
>Now other question. I have a dual 2 ohm sub. I have it wired
to a final 4ohm load and 1 set of wires from the terminal of the
box.
>would I get more power if I ran 1 set per coil off the sub to
each terminal of the mini? would the amp see 2 ohm or does it
internally change the load?
>I do not want to damage the amp nor run @ 1ohm
>that is the reason for the elementary questions. I want it
hooked up right. I am not used to all these options
>sincerley appreciate the help. nice amp btw.
Might be internally bridged.
thats what I was trying to find out but he finally replied and said he made a mistake and that it couldnt be wired to 2 ohms.
He has too many amps floating around in his head. :)
