Just got a Fluke 87 ture rms multimeter My link
I don't know if it is accurate or what but i read the owners manual and am mind boggled. how do I tell the voltage readout on this thing?
It says ac voltage=2.5 but i know thats not right. any ideas??
Thanks
Matt Cusack
for starters what are you measuring?
battery voltage?
amp output?
but i assume you are measuring the amp output b/c you are in the a/c setting and you are setting your gain...
so with this first disconnect the sub then put the dmm into those terminals and play a 50-60hz tone and turn your h/u 75% of the way up and this is for the sub stage i am talking about
I'm trying to measure the voltage on my amp so i can adjust my stinger voltage meter
o in that case put the fluke on DC the --- not the ~ symbol and touch the positive and negative terminals on the amp, where you plug the wires into to give the amp power!
remember the amp TAKES DC voltage and outputs A/C voltage
not a thread high jack... but...
I want to setup my JL Audio amplifier so I can get the correct gain setting...
What do I select on my DMM? Thanks
2 Clicks to the right. 200 acv
Black cord in the com port, red cord in the left port. (10a)
Thanks... Jumping in the car now! :)
So I tried last night and again this morning .... Only thing that happened was this threw my amplifier into "low impedance" mode ... I didn't get any real readings at all... :(
The red cord actually goes into the right port. A is for Amps, V ohm etc is what you want for voltage.
edit: Whoops, your left, not the pictures left lol. Disregard this if you put it in the right one.
Edited by ulrisa
