JayAreCWB
2 15" NSv2?What 2amps?
Im planning on getting 2 15" NightShades v2 and was wondering if I should go with 2 saz2500s or 2 1500s. i know SD underrates just about everything so what do yall recommend? Also what else should I get as in electrical. how many batts and im guessing i would need a HO alt? Ill most likely do the big3 as well.
hey man my current setup is (WAS i am in the process of getting 2-12inch ns in a 6th order box)
2-SAZ2500
2-15inch NS v1
2-NSB90 (batteries)
1-H/o (220amps)
1- Big 3 in 1/0 wire
some sound deadener
2-(sets) Zapco RB 13.2 (comps)
1-SAX100.4
and that is about it! i hope this helps you with your decision
I used to have 2-15inch NS v1 in a down firing 4th order box but i am changing that to 2-12inch in a taped 6th order horn box design. see in my little car i didn't have enough air space and i was choking my subs out so in the long run i am switching to 12's to give them the ideal air space!
with 2-15inch i hit 146.98db's on tl
with 1-15inch i hit 145.00db on tl
at any rate there you go!
2-SAZ2500
2-15inch NS v1
2-NSB90 (batteries)
1-H/o (220amps)
some sound deadener
1-SAX100.4
Thanks a lot CrazyKen! That gives me an idea of what Ill need. I have a Jeep Grand Cherokee so Ill have the space for 15s
aww one of those jeeps! be sure to use sound deadener! and good luck!
also buy a voltage meter so you can keep an eye on your voltage while playing! make sense i would recommend the stinger blue volt meter b/c i use it and i like it plus it is blue like the sundown audio turn on light on the amps! lol
and if you do buy a stinger be sure to SET / calibrate the meter in reference to a volt meter. to do this remove the cover and find the yellow Phillip screw and turn away! lol
http://cgi.ebay.com/STINGER-SVMB-VOLTMETER-BLUE-3-DIGIT-DIGITAL-DISPLAY-NEW-/360194054151?pt=LH_DefaultDomain_0&hash=item53dd3d1807
Yea one of those jeeps!! lol ill be sure to get a lot of sound deadener. Ill see what I can find a good deal on. And def need a volt meter!
the sound deadener i like to use is made by B-Quite!
it is a canadian product which ships to america for a cheap price!
it doesn't cost to much and the cheap stuff is all i use and it works pretty good! check it out
the good stuff
http://www.b-quiet.com/ultimate.html
the stuff i use
http://www.b-quiet.com/extreme.html
