c0smo kram3r
DC Lv5 18" Enclosure
Ok guys, I'm gonna need some help with an enclosure. First, some background. I have a friend who everyone had him talked into buying the usual kicker stuff, but luckily I got to him in time. This will be his first setup. Anyways, I coached him through buying an AQ2200D (could have chosen a better amp, I know, but his budget was sort of limited and we didn't feel like going through the hassle of looking for used deals on others), an 18" DC Lv5, and all the other bits. Should all be getting here by the end of this week.
Alright now to the enclosure:
The vehicle is a 2005 Tahoe Z71 (captain chairs in the rear). Now I measured awhile back, but if I remembered right, it should be 42" (side-side), and 33" (backseat-tailgate) (I'll double check asap). We want to do sub up/ports up or sub up/port back (suggestions?) with sub in the middle and a port on each side (sub up/ports up), or have sub in middle with port on the back. Now the only stipulation is, he would like to have some room to put a cooler/luggage back there. So we were thinking of using up all the room from side to side, and only using what's needed going back to get the optimal volume. We're thinking of placing the battery between the captain seats and making a battery/amp rack to hide the battery.
I'm most likely going to be using 1" MDF all the way around and double it up for the baffle with of coursed 45 degreed angles. Do you think we should use further bracing? And I know that DC hasn't done any parameters on it, so what's everybody doing for them (volume, port area, etc)? Also, if it's possible, would anyone be willing to sketch us up a drawing?
Thanks in advance.
