whitesharingan
How to wire a DVC in parallel.
I've seen a few different ways to wire a DVC sub
in parallel. but which way is right?
Here are a few diagrams that I have found online:
Everything Car Audio: Single DVC Subwoofer wiring
Subwoofer Wiring Diagrams, One 2 ohm Dual Voice Coil (DVC) Speaker
Are either of these ways right or wrong?
Any help is greatly appreciated.
second link, first option
Edit: Why did you ask this is Fi's section?
lower ohm of resistance => the more the amp/your electrical has to work
If you have a dual 2ohm sub make sure you're amp is stable down to 1 ohm. If so that would be more of a load on the amp but produce more power. If youre amp is not 1 ohm stable wire it in series would put less of a load on the amp but produce less power.
I have a Rockford Fosgate T2500.1BD and I have it
wired like the first diagram I displayed.
Is that an actual 1 ohm load?
Yes!
