agiletick
question about strapping
small question is the BR cable just a normal rca cable or is it something different i need
yep normal cable.
Just use a typical rca cable, just one of the two ends and run from Master BR Out to Slave BR in.
Remember, whatever amp that has the headunits rcas going into it, that's the Master and that's the amp that will use BR Out
yep normal cable.
Thanks yeah i have read all about how to run them but the only reference i found to BR cable was to use a "mono" rca didnt know what that was so thought i would ask first
it is always good to ask before you do! even if it seems like common knowledge!!
which 2 amps are you strapping?
2 saz-1500d on 4 sa-10's
