jer
Need help (building box for 2*sa12
1. Sorry for my poor english (i'am from russia)
I need help to build ported box for 2*sa12 (1 ohm connection) amp - Rockford fosgate t1500-1bd, i'd like port to be tuned to 40-42 hz
Can anybody help me with dimensions of box and dimensions of port. Thank you very much.
In russian discusion a can not find any info about that
Mounting Depth = 6.5"
Cut-Out = 10 15/16"
Displacement = 0.14 ft^3
Overall OD with Gasket = 12.5"
Enclosure Suggestions:
1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz
* Tune higher and use a smaller box for more SPL oriented setup (Use 1 - 1.5 cubes)
* Enclosure can be as big as 2.25 ft^3 with lower power levels
1.00 ft^3 sealed -- F3 of 44 Hz
* For SQ and space limited applications
I would tune it a little lower (between 30-35Hz)
I can find nobody to translate what i d like to say. What dimensions of box and port needed to tune it to 35 hz? I am listening club and electro music, its ok with that way tuned box (35hz)? Thanks for answers
jer if you can give us the maximum dimensions of your trunk i would be happy to design the box for you
tyoung515 thanks, i need just enclosure volume, area and lenght of port for 40-42 hz tune, my car is mazda 3 hatchback
well i would try 3 cf@40hz, port that is 10"t by 3"w will need to be 11.75" long, hope this helps!
thank you very much, tomorrow i get the subs, and start building
