nick9892
Electrical For A FI BTL
Ok guys just wondering what you would recommend me I can do on my current electrical. Currently I have an 18 Fi Bl d2 running with a sundown Saz-1500d. My electical consists of the big three being done in 1/0 gauge and an optima yellow top up front with around 1000 ca and a newer Ford 700ca battery in back. I am just looking for a setup to get lower and louder than the BL can. The Bl is in a 7.3ish cu ft book tuned at like 31-32 hz. Currently my headlights lights have almost no dimming whatsoever so I know I have a decent electrical. My budgets right around 800. So I'm looking into selling the BL on here and getting the BTL. I'd probably end up building a new box for the BTL and tune around 28-30 hz. But for an amp, do you think I could run an Aq 2200d at 1 ohm sufficiently with my electrical? Thanks for the suggestions and any input.
You need to focus on AH no CA or CCA.
What ohm load are you running right now?
Gain 1/2 way could still = heavy clipping. . .
From a 1500D to a 2200D will not big a huge difference in electrical stress. You have a decent electrical system, install everything and then upgrade as required.
Brian
You may not even hear a difference with your upgrade. The new box - yes, the rest - maybe
