B.us.T
Help ! Box for FI BL 10
Hey guys ,
i want to build an sq box for my FI BL 10 !
I hope you can help me with the port an the size of the box !
Thanks for helping me !
Nice regards
Hey guys ,
Nice regards
How about you tell us a little more information, I'm going to assume this is going in a car.
What vehicle?
How much space do you have to work with? Give us max dimensions, volume.
How much space are you willing to give up from above. Bigger box and you can run less power and have equivalent output but sacrifice space, or you could run a smaller box with more power (if your electrical can handle it, not sure what amp you have, etc.)...
car: VW Golf 3
Amp: Steg K2.04
Batterie: Hawker HX 300
The volume of the box i want to know from you and the best porttuning for sq.
Only the width is max 31,5 in .
The box have to punch very hard and have to sounds god !
Sorry for my littel bad english !
You could 16"x16"x16" with 0.75" mdf that would put you around 1.76cubes then after driver displacement, port displacement you'd be right around 1.5cubes, which is optimal from fi.
But it's really up to you how/where you want the box located in the back. you could do 14"x18"x16" or 20"x12"x16", etc get my point?
From your vague details of what you want it to do "punch hard and sound good" I would tune around 33hz.
Are you building the box or having someone else build it?
