i got a question about a rockford fosgate amp
so.....
i got a fi bl 12'' and had it hooked up to a planet audio rxd1000 and it worked fine but was really underpowered
just got mt new amp in today , a rockford fosgate r1000-1d and my sub isnt working now
i checked everything from remote wire, to fuses, to how i wired the sub and i cant find out why it isnt working
any ideas please?
One thing that would help would be to give us what troubleshooting you have done so far. Is the amp powering up? Is it going into protect? Did you do anything to the wiring at the sub?
Answering these questions and a few more like them can help us help you out, which we'll be glad to do whatever we can.
YOUR AMPS BROKEN, IT DOESNT WORK.
seriously if you want an answer to your problem then you need to give us something to work with. Saying it won't put power to the driver is utterly useless.
Answer Alton's questions and we'll get you on the right path :fing34:
sorry fellas
amp gets power
doesn't go into protection
didn't touch the wiring of the sub
checked my ground
checked remote wire
fuses are good
im pretty new to this so i barely know the basics
Gonna ask a few silly sounding questions here to cover the basics.
Are the RCA's plugged into the IN jacks and not the PASS THRU jacks?
Where are the GAIN and LP knobs adjusted to?
How are the speaker connections made at the speaker terminals?
What is the coil configuration on the sub?
RCA's are plugged into input
tried tinkering around with the gain to see if the sub made any noise and nothing , i could try again tho
speaker connection at the terminals, does that mean how i have it wired
like since mt sub is a dual 1 ohm, i wired it at 2 ohms ?
You have the coils wired in series then? If it were wired in parallel instead that would present a .5 ohm load at the amp which SHOULD probably put the amp into protection and cause it to not play anything. Though that would really depend on the amp and how the protection circuitry is designed.
Do you have a DMM?
Also, have you checked both ends of your RCA's to verify they're still plugged in? (sounds silly, but I've seen it happen)
Can you re-install your old amp and verify everything is working? There is ALWAYS a chance that the new one is bad out of the box. While it's VERY rare, it does happen.
Do you have a DMM?
so since i have my sub wired in series and my amp is parallel it wont work?
if i re wire the sub to a .5 load, and my amp goes into protection is that bad or a good sign?
whats DMM?
whats DMM?
That's not really what I was trying to say. If the sub is wired in series then you're good to go. I was wanting to make sure you KNOW for certain that the sub is wired series. Where the amp says it's parallel is only referring to the internal configuration of the terminals and has no effect on the wiring of your subs. Please DO NOT wire the sub to .5 ohm on purpose. A DMM is a digital multi-meter, used to test voltages, resistance, continuity and more depending on the unit. If you have a DMM you could connect it to the sub and verify for certain that you're wired in series.
did u wire the sub in series just for the rockford amp or was it wired that way on the other amp too?
i havent changed the wiring at all
so yeah it was wired in series on the other amp too
if its in series, and its a single driver dual 1ohm then its going to put a 2ohm load on your amp, which is fine :)
i just dont get why my sub isnt bumping tho
i had it bumping yesterday on my other amp and it was fine
i got my new amp today
hooked it all up, made sure everything was good went to play some music
and no bass
whats music without bass haha
got ,my amp working finally
thanks for the help you guys appreciate it
What was the issue?
I'm glad it's working now. Just as bassahaulic asked, what did the issue end up being?
Yeah, what kind of buster on a car audio board tells us he fixes something then doesn't tell us what happened?
His status: "got my amp working, damn speaker wire,"
So something to do with his wiring?
What was the issue?
the way i wired the positive and negative to my amp
1 2 3 4
i tried 1 and 4
then 1 and 3
finally i did 2 and 4
and my sub was working
not slappin as hard as i thought it would tho
maybe it needs to be broken in more but i think it should be louder then what it is
