M82a1snake
two 18" BTL's build
and i got two AQ 2200D's
http://yfrog.com/j6imag0090fj
http://yfrog.com/9fimag0091ej
and coming soonn i plan to either build a walled off box or an up fire box, i still am waiting for my HO alt a 350 amp from alternatorparts.com 350 amp alt with external outboard rectifying bridge! ;) and im going to have 7 yellow top optimas cuz i have MADD hookup on yellow tops for brand new $50 bucks a yellow top from my cuzin! im probably going to use 2/0 awg power and ground wire , its welding wire lol 00 AWG (-1 AWG) wire haha but i might just use two strands of zero. only thing im not sure about is if i should run a relay inbetween each battery to limit current, or if i should just parallel all batteries together , or run all of em independant off the HO Alt. tell me what you think box will be tuned to 32-36 hz im not too sure cuz i dont know how to account for large amounts of resin bracing on the walls of the box.
I would run all batteries parallel instead of having each one ran to the alternator individually.
