sundownz
Building a Nightshade v.2 Production Unit
A customer ordered four 15s and I am just about done with the first so I took a few pictures along the build process :
* Rear triple joint glue and ring - the ring is smaller than the gap and centered so can go down into the gap at extremely high rearward throw.
* Close-up of the glue.
* Spider pack is pressed with a laser cut steel plate and a Z v.2 motor to ensure good bonding of the glue between the frame and spider layers.
* Terminals have a locking toothed washer
* Soldered - and a dab of glue added to the stud on top of the nut and washer for long term safety.
* Special surround glue - dries flexible and won't hurt the surround material.
* Finished cone to spider joint.
* Top triple joint ring initial placement.
* Some glue added.
* Final glue bead.
* Leads fully encapsulated.
* Leads placed into the cone - care taken to allow adequate slack for high excursion.
Suffice to say the NS v.2 is put together quite well.
Obviously this does not cover EVERY step of the process :) But you can get a good idea of what goes into it !
:djparty: very nice. keep up the good work!
Sweet looks TOUGH!
i gotta gettem
nice pics, can wait to see mine in person!
this is like watching how its made, i love it.
Very nice! I like the attention to detail and the quality of the glue joints! Sundown ftw!
By chance are these mine you're building? :woot:
Yep ! I started on the 3rd one today.
Brandon is tied up building a bunch of woofers for Russia so I'm working on yours myself.
We've really spent alot of time on improving glue joints -- it's very critical in this type of woofer. We gained alot of experience with different methods on the v.1 Nightshade -- some worked and some didn't... it was really a huge learning experience in how to make woofers take more abuse.
Also, big thanks in order, I spent some time studying the work of David Moore (FixMySpeaker / PSI) down at SBN and took away some good tips from him -- having built thousands of speakers he was a great resource to learn from. I have alot of respect for Dave and his custom work and refer customers to him often -- and I am very thankful for his advise!
