iputon326
cut id for lethal injection
im building a box for 2 15" lethal injections and i need to know the cut id for the subs.
sweet thanks. i woulda txted you but the screen on my fone broke when i was carrying the wood lol.
:Doh:
gah i fuck up everything. i just cut the hole for the sub and i wasnt paying attention and cut it right above the port. so the sub is the closest to the port instead of far away.
Edited by iputon326
gah i fuck up everything. i just cut the whole for the sub and i wasnt paying attention and cut it right above the port. so the sub is the closest to the port instead of far away.
:fryingpan:
since i messed it up how will it effect it? i mean its right above the port.
im bout to just build a whole other box. i only put one in and havnt even started on the other box yet.
or i was thinking just cut another piece and put it over the hole and cut the other one.
and i havnt put the second baffle on it yet so i might still be able to fix it?
Edited by iputon326
If you can somehow fix it, I would recommend it.
how would it effect the output like it is now?
Not sure, I have had good results with the woofer farthest away from the port throat.
alrighty thanks. im about to go fix it now.
It's not going to matter.
Try it and if you don't like it you can always change it.
it doesnt effect it at all?
Why do you think it would?
