Curtis96olds
need aero port help
ok i plan on running 2 SSD 12's off a AQ1200D @ 1 ohm. the box it gonna be roughly 4.4 cubes depending on how much the aeros take up for space. what would you guys suggest for aero size? i know i would need less port area for aeros then say a slot port but im not sure how much less i can use. i was thinking 1 6" aero which would give me 28 sq inches of port area (6.27 per cube) or i was thinking of going with 3 4" aeros which would give me 37 sq inches of port area (8.69 per cube) now i know thats less then the recommended port area for slot ports but i was wondering if either of those would be acceptable for aero ports.
You can normally run 50% less port area on aeros vs standard slot.
I did 4 4" aeros in 7ft^3 tuned to 37hz for my 18" IA Death Row and it moves some serious air.
do you think i would be fine with the 1 6" aero then? thats roughly 50% port area then recommended
Well that's roughly 50% of the minimum port area recommended per cube. The 3 4'' will definitely work. The 1 6'' will probably be fine.. but IMO, 3 4''
I would say 2 4"aeros would be more than enough.
hmm ok that sounds good guys, thanks, either way i go it seems like it would be enough port area, so i might go with the 3 4 " aeros to be safe.
Edited by curt96olds
I'd go with three 4s
