klee7013
SA-8 Noob Question
Trying to wire up now- not worried about what ohm to wire it up to got that
i got 3 and i am wiring it to 1.33 ohms
and i was gonna just use the wire terminal as a jumper to get the neutral and power wire to the other subs
like 2 wires on the terminals on 2 of the subs and the last sub will just have 1 wire into all the terminals because i dont have to jump it on the far end
so my question is can two 12 gauge wires fit in one of the terminal in the sa8-- if not would it be better to run a seperate run for each speaker to where the wires are coming into the box- or would wire nutting them and getting a good tape job be good enough
cant wait to try these out-to make sure my box is good so i can put the evercoat rage on and wrap it up so i can be bumping again
thanks
kevin
Edited by klee7013
You can actually go smaller when wiring from terminal to terminal.
I actually like to wire each + and - to the binding posts themselves.
X2
hmmm thanks for the feedback- guess i need to go buy some more wire :(
just cut some strands off the 12 gauge so it fits in the terminal. no need to buy smaller wire..
