havinnoj
HavinnOJ's New Build - Thoughts/Questions
Hey boys -
I'm planning out a new system for my 03 F-150 Harley Davidson.
The only 2 things set in stone are the JL Stealthbox - 12w3v3-4 which should take about 400watts rms. And the H/U (for now) is a Alpine 9886. I have the H/U but need to buy the JL - anybody have a good place to buy JL at less than retail?
I'd like to run DLS UP6i speakers up front with a Sundown 125.2. They recommend 150watts RMS so I don't know if the Sundown will be sufficient for it. Thoughts? Do I need a seperate amp for the tweeters?
For the sub I need something solid 400watts rms. Maybe the 125.2 bridged?
What would be good rear fill? Only experienced info on this question please!
The 125.2 is a very good match for your comp set.
You don't need rear speakers at all.
For the sub, you can use a 125.2 bridged. But you can use a 1000saz at 4 ohms or 2 ohms(300 or 600 watts) so you can add another sub later.
