'05 f150 silent inside
For the grill, i've been wanting to try this idea out for a very long time.
Have the box regular.. just a straight ported/sealed box, then... get a piece of wood of your choice, get it about an inch thick, then get a sheet off plexi glass about 2/4 or 1/4 thick and cut the wood so it would frame around the plexi glass and have about an inch lip going inward on the frame them with a tool of your choice sand down the wood so the plexi glass fits in flush then.. cut holes about the size of the bottom of a styrofoam cup (or smaller/bigger) out of the plexi glass and then add some led lights (color green cause green is fuckin dope) then boom!
just make sure there is enough room from the face baffle of the box and the back of the plexi glass for sub excursion.
...this idea might sound/look better in my head
Hey Einstein, 2/4 is a 1/2! You need to check and see if the 3rd grade will take you back! Maybe then, you'll have a chance not sound like a derelict when you attempt to write.
Edited by '05 f150 silent inside
