sundownz
The Jeep : 4th Order No-Wall Build
Decided to finally get started on it. The Jeep will be getting a no-wall 4th order build with two 15s.
* Battery / Amp Rack area cleaned out... everything un-installed. My multi-channels will sit on those two little platforms where the batteries used to be.
* New floor piece cut - everything will attach to this piece.
* Of course XS Power D1600s will be used :)
That is all for now... just ripped it all out this morning and Brandon helped me cut out the floor piece. Will make progress when time allows.
:popcorn:
:peepwall: , Ill be back for more
Nice. What kind of wood did you use for the floor piece?
Aruco ply from Lowes. Similar performance to Birch ** but a good bit cheaper... have used it before and it worked well for me.
** - It is stronger than "cabinet grade birch" but not as strong as "baltic birch" -- typically the cabinet grade is what is sold at Lowes and ONLY the faces are actually birch.
Reference : http://eberhardt.bz/GME_Wood_Land/GME_Woodworking_Stuff/0_Techniques_Information/Tech/P3_Plywood_for_Shop_Tech.pdf
Tuned in for the progress .... :popcorn:
* Floor installed... checked with a level.
* SAX-125.2 under this side (midbass)
* SAX-50.4 under this side (midrange and tweeters)
I will eventually build a cover for this lower area as that should help increase SPL.
i use Aruco, there was a sale out here that had it for 17 a sheet lol, its a lil soft but works really well, looken good jacob
NICE!! tuned in for this one!! and nice floor! looks very cool!
I want more PICS :)
Start thread jack / E-Mail me back foo \ End thread jack.
Are you sure Brandon helped you with that its way to sexxy!!!!
LMAO!!!!! :lol:
This build should be loud.... Is there any particular reason why you went with a 4th order?
LMAO!!!!! :lol:
They work well for SPL :) I have helped with several 4th order full walls that worked great... and we have a local in South Carolina doing a 4th order no-wall that works great as well.
:popcorn:
Been slammed with pre-orders -- next week will be about the same. Then I should be caught up and have time to mess with it.
