zaco2356
sundown sax-100.4
can a sazx-100.4 handle 2 ohm on bridge mode?, if any one have try it before, let me know thanks
I'm sure it CAN, but I wouldn't try it. I thought about it but decided against it.
ok, i want to try it but i don't want to damage the amp, i asking cause i know sundown is underrated and is capable of doing more that it said,...... has some use this amp in bridge mode at 2ohm ?
I don't suggest it... will add alot of stress to the amp and significantly shorten it's life span.
ok thanks, my prject consist in 4 - 8" midrange and 4-8" midbass but all then are 8ohm each so it was going to be 4 -8 in each bridge for a load of 2 ohm, i guess i have to find some midrange and midbass that are 4ohm each so i can put 2 in each channel for a load of 2 ohm each....thank quick answer
