joe_prince
Subwoofer length for Fi BL 15?
Just wondering so i'll know how much plexi glass to get so you can see the whole subwoofer while it's sitting in the box. So it's obviously 15" wide put how tall is it? Hope someone can help me or Nick over at Fi.
Thank you
OD and everything is on the site..under the specs of every sub.
Thank you Nick and i actually changed my mind to the BL12's, and was wondering if a 5cubes box tuned to 33Hz work well?
Also do i look at the mounting depth of the OD?
Edited by joe_prince
BL 12 – Ported box we recommend using 1.8-2.5 cubic feet @ 30-37Hz (I personally think that a 32hz tuning is optimal, and has the most output and is still the most musical daily driving). Use 12-16 square inches of vent area per cubic foot of volume.
I don't understand what you mean by the mounting depth of the OD?
If you are flush mounting something then just use 2 pieces of 3/4" MDF and you'll be fine. Cut the outer piece a little bigger then the outer diameter of the woofer to give you some wiggle room.
