ShaiTan
XCON 12
Does anyone know the exact mounting hole diameter for the XCON 12? Not the individual hole size. But the entire mounting circle.
If your trying to make it flush mount just take out the rubber thing and trace there you go...
:peepwall:
Dang bro, it's right on the page where you ordered them,.
•Sub Outside Dia.: 12.500”
•Cut Inside Dia.: 11.150"
That is the outer diameter and the cutout diameter. I want the screw hole diameter around the sub.
I just set them in there and hit the holes with a Sharpie, then take it out and drill holes.
Helps me make sure i am centered too so I dont drill a hole too close to the edge that wont hold a screw.
x2, the same method I use as well.
