abigor
12" in a 2.5 cu.ft. vs 15" in 3 cu.ft.
8 members have voted
  1. 1. What will sound good in a trunk
    • 12" in 2.5 cu.ft. tuned in 37hz
      5
    • 15" in 3 cu.ft. tuned in 37hz
      3
Hello Guys,
What do you think will work best for me and will sound louder, 12" in a 2.5 cu.ft. or 15" in 3 cu.ft. both will be tuned 37hz? Brand is IA Warden.
Recommended enclosure for 12" - 2-3 cu. ft.
Recommended enclosure for 15" - 3-5 cu. ft.
Thanks in advance!
Edited by abigor
Depends on the subwoofer and it's T/S parameters!
It will be both IA warden, and as we all know warden don't have any T/S.
BTW it will be powered by two 2000watts strapped 4k in total.
They do have T/S parameters, they just aren't listed. Go with the 12" as you don't have enough room for a proper enclosure for a 15".
This, I always like going with the smaller setup. It allows you more room to play around with box designs.
If you have 3 cuft NET volume and proper port area, I would do the 15", since you have 4000 watts. . .
I have run 15" BTL's and Mayhems in less than 3 ft and they sounded great.
I always liked smaller setups... More impressive. Both are going to be loud as all H E double hockey sticks, and the Wardens handle plenty of power, so I'd do the 1 12, because I think that the larger box size, (in proportion to the driver), could get louder.
Are you sure you have enough room for port area for the 15?
Edited by Don Ganso
Yes, if u havent factored in port area yet... then it sounds like 12 would be the way to go but the 15 in 3 cubes is fine.
Yes they do have T/S parameters but according to Nick they don't have the fix T/S for warden as it always change because its an SPL subwoofer.
Yes, 3cu. ft. is a net volume after port and sub displacement.
You want it to sound good, but you tune it to 37hz?
I don't know if the 12 would handle the 4k w RMS in a 2.5cu ft enclosure.(maybe if you're responsible with it) :peepwall:
So what's your recommended tuning? I mostly listening to rap, RnB and techno/trance/house.
If you listen the most to technp/trance/house, then 37hz would be perfect.
But if you listen more to rap, and like to have lot's of lows, then 33hz would be better.
