nigerlet
What Ohm To Get?
I don't understand ohms at all.
But I'm ordering a 15'' BTL with an audioque 2200 watt amp.
So it will just be 1 sub, 1 amp.
What ohm should I run?
and can somone maybe explain what it means to me?
The amp does 2200w RMS at 1 ohm, so you want the final load from the sub to be 1 ohm as well.
Subwoofer Wiring Diagrams
Check out that website. Just choose how many subs, and which voice coil config, and it will tell you how to wire and what it goes down to.
your amp is 1ohm stable, so get a dual 2ohm driver and that will put a 1ohm load on your amp, then you'll be set :)
