CrazyKenKid
Orion Cobalt CS 500.5
Hey guys I am looking into buying the above listed amp (orion cobalt cs 500.5) but for some reason I can't find the specs for this amp. So far the ONLY specs I have found but NOT confirmed are
RMS Power at 2 Ohms: -1 W x 50
Epinions.com - Search Results: Orion Cobalt $ 500
_5_Amplifier___Cobalt_CS_500_5
(whatever that means)
and 50x4@4ohm and 200x1@ xxOHM
basically if it is 50x4@4ohm that is good but if it is 200x1@4ohm that isn't good lol.
so if ANYONE has better Google skills then me please help me out or if anyone can verify with past experiences or a manual that would be awesome!
and here is a pic of it!
thanks
Kenneth
well that was short lived! I jsut got the answer e-mailed to me!
specs.
HAS 500.5 POWER OUTPUT
4 x 50 @ 4 Ohm
1 x 150 @ 4 Ohm
4 x 75 @ 2 Ohm
2 x 300 @ 2 Ohm
SIGNAL PROCESSING Three continuously variable high pass (30Hz - 1kHz) or low-pass (30Hz - 2.5kHz) FUSE SIZE (2) 40 ATC DIMENSIONS 15.7" x 10.1" x 2" (400mm x 226mm x 61.2mm)
The older Colbalt amps were decent amps, nothing fancey but good.
