im running 0 gauge, from redtop, to a kicker 1500. which the battery terminals are 2 i believe. more or less, am i gonna be using power if i use gauge reducers?
will you be losing power if you use a reducer?
no! the reason for a reducer is to fit bigger wire (with a higher current rating) into a smaller hole!! ;)
