Notorious97200
round port, slot port ?
I have read a lot on the subject, but I can't get a final answer.
Like a lot of people in my country (we have small cars), I have limited space in my trunk, but still want to use a ported box.
I've read that round ports can make me save space. But I don't understand how. The same rules should apply : 12-16 sq inch of port area per ch ft.
What can I expect for a 3.5 cu ft box ? I would like to make a smaller box so that my amps can breathe :)
Thanks
Actual port wall displacement is smaller with round ports compared to slot ports but it will depend on the application.
Using a flared round port / aeroport is going to help decrease port air velocity, meaning you can use less port area than when using a slot port.
Ok
I got it !
But what is the rule ? I can use less port area, but how much less ?
And How to choose from 1 port, 2 ports,...?
Maybe someone can post a link where I can find all the info I need.
Thanks Adrian
How much port area you need will depend on:
Driver size/parameters
How much power you will run
Tuning frequency
Type of port used
Notice I did not say anything about using box volume to determine port area :)
If you want the true required port area for the port to function 100% as it should, you can use this:
PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES
But I will warn you, it will ask for a big port. You can get away with less in a car, and even less if you use a flared port. . .
Is this for the Xcon 15 and SAZ1500 mentioned in you signature?
Brian
Tuning frequency
Type of port used
Brian
Yes it is, Sir.
I would like to try a box with aeroport, if it can be smaller than my actual one : 3.5 ft3 net @ 32 hz.
In my country, people are afraid of big box in their small trunk !
(This is still me, it's my mobile account)
Edited by Notorious from Martinique
