cheese20323
Legit Sub Box calculator
What is the most accurate sub box calculator tuning and everything
Pencil and paper.
If it is a slot port the port needs to be in the enclosure to figure net volume, ie don't figure out port displacement and subtract it from gross volume to get net volume. You can calculate round ports separately.
I've always used winISD.
Pencil and paper.
What about if i want a square
square is the same to figure net volume. but also does not need any end correction figured in. here's a link to a box tuning calculator i made in visual basic. i'm about to make a separate thread for it now
Torres' (ExpoSport) Box Tuning Calculator UPDATED 3/10 - SMD Forum
Maybe it is me but Im not getting accurate results with your box when I compare to other legit programs, I downloaded all versions and network and everything. Just a heads up :peepwall:
