schuffler
12" BTL Enclosure Question
Whats a good port length for the BTL as a daily driver tuned around the recommended 32 hz and 14in^2 per cube? 2000rms power.
Enclosure will be glassed into the side of my trunk and I have around 4600in^3 before any displacements to work with. So should be around 2cuft after. Trying to see if I can make a ported enclosure work or not.
Thanks!
Thanks!
real rough guess, about 22" long with that much port area to get you down to low 30's
