swift
new truck box design
I will be soon upgrading my current sub and box setup in my F250. I am limited on space and think I can go 1.5cu without much issue or maybe even up to 2.cu if I add an extension piece.
My goal here louder deeper harder hitting setup.
Here is a pic of the space I can work with and my current box.
1 10in Fosgate p2 in .53 sealed.
I can easily double the size of the current box or I can make almost like a L shaped box to utilize the lower section behind the pass side.
Without using the the lower pass side I think I could do one that is (17in H.. 33in W.... 5in D1.....8in D2) this would be outside diameter and I will be using 3/4 MDF.
This should be about perfect for one 12in Icon sealed correct?
Or should I use that other side aswell and do two 10in Icons with no separator between in roughly 2.cu sealed (total) or just do two sealed Icon 10's in .70 each side.
Does anyone see anything I dont? the back seats do not slide forward, just recline.
Looking for all around good sound and something that will hit hard and low.
Thanks
You need to come down here to Pro Audio in Richland, Ms. I-55 south to hwy 49 south. He has a F-250 set up with one 8" in his truck. That thing JAMS !!! That enclosure is AWESOME ... His name is Buddy Ham. Used to be a great competitor in car audio.
