hhowell1990
Split Port
Will using 2 ports work or will my tuning be off? I'm going to be running a Fi BTL 18 in a 6 cube box and want to run 2 ports, one firing left, and one firing right. as long as I have the same area and length would I be OK?
no, each port will still need to be a little bit longer even when maintaining the same port area as one large port.
would it need to be longer simply because the material would take up more volume in the box?
No.
You can enter your port specifications in this site and see the length. Then type 2 for ports instead of 1 and see what happens... double and more for port length.
PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES
READ ME
