I8apony19
Mag Installs
I want to see everyone's installs....
EVERYONE'S
PICTURES PLEASE!!!....no excuses....
My install is temporary and crappy :P .... sounds good though :D
Edited by Jordan94z
i will not show pictures of my install because it doesent exist yet :P
P.S.--where are you pics clarke?? no excuses :D
:+1:
SO???
Pictures Jordan...I'm in the mood to point and laugh....
Just kidding...I just want to see....
Hollis...I'll bust out my fiberglass pics if you'd like???
I've been trying to get those glass pics for a while now. It's amazing what Clarke is able to get done considering he doesn't even own a DRILL! :blink:
Probably not as nice as some of the other installs but here's mine. It's 2 cubes @ 29Hz built by Woodlawn Cabinetry with the amps mounted on a sliding amp rack attached to the other side of the enclosure.
Edited by dnosryd
wow I like the dual port design, :poop:
ill post them up for you if you dont :D
:+1:
This is the original install in a stealthbox I had, now its in a lot bigger box in the well, see if I can find one...
nice real nice
i did a fiberglass box in the same spot like that but we inverted the sub...
it was a 12A talk about looks good with the sub backwards...
PS: the guy is going to let me put 3-12s back there this summer, and it will be most likelly 3-12Magnums.
ill take pics of that for sure.......
jamie
Very nice install indeed. That Mag has got to be shoved in there! We had to put Josh's in the bottom of his hatch. But that's a very good looking, very compact, install.
Plain & simple,pounds like a mofo.The car is crying for some some deadening,just too cold out to do anything....Big Lou
Edited by strong*I*bumpin
Thanks, and yes it definately was a tight fit :D .. I saw a picture of Josh's once awhile ago, what size box was his in exactly? the stealth was around 1 cuft, the box it's in now is around 1.7ish...
thanks xtrmeasures.. 3 of these 12's in a camaro would be rediculous :lol:
strong I bumpin thats very simple and clean looks great
found one, the lighting is a little weird but you get the idea, and yes, it is mounted a little crooked... it was mounted straight originally but was taken out and re-installed, I started missing it B)
Edited by Jordan94z
those are awsome shots, one of those are dead links, but keep them comming
Josh's is actually in what we believe is 0.8 cubes. We just build the box, installed his two amps (one is under the visible amp, which makes two nestled in that enclosure), and inverted the Magnum. It sounds fantasic, so we're not worrying about enclosure volume estimates. :D
Nice pics guys. I'll add mine later today when i get home. Right now im at school. But mine isnt half as clean as all of you. I guess since i just built my box saturday, but i'll post pics
so THAT'S where the prototype went...
My suggestion would be to invert the one without the dust cap decal...
very nice man, and is that really the prototype D2?
