Rush24
Box Help
If anyone could draw me up some designs for 1 15" bl send me a MSG and I'll give u measurements of my trunk.
Website says 3-5 cubic foot.. So shuld I go 3 4 or 5? Wuld it fck with the sub if I went bigger or smaller then reccomended? I was lookin at sme pro boxes and this one is 3.87 Cft. Any1 reccomend pro boxes or would I be better off gettin one made?
Everything will depend on how much room you have available, so go get the maximum dimensions you can use for a box (make sure you leave room for you box to move air into the cabin, amps to breathe and secondary batteries if any).
Usually the bigger the more efficient it makes the speaker and the less power it needs before running into mechanical issues, will also have a greater low end response.
Usually the smaller the enclosure the less efficient it makes the speaker and the more power it needs before running into thermal issues.
You wont mess up the sub by going with smaller or bigger than recommended but it will drastically affect the sound.
You should ask one of the many enclosure designers here that question. They have their own section and lots of guys will sell you one.
