PhishHead
IA Lethal Injection Sub Box.
I'm shipping from CA, but that 170 includes shipping. But with flush mount and double baffle it will come out to $180 even.
Let me know when you can give a 25% deposit so I can get building. It should only take a day to build once I get my jasper jig in (broke my old one :( )
Also what are you max dimensions?
Andrew
Yea Argent I would like to get the double baffle and flush mount. How long will the box take to make? I should have my tax money by March 6th. Where are you shipping from?
Thanks,
Jeremy.
Also anyone know a good amp to use for the 12'' Lethal Injection? What would be the benefit of wiring 1 ohm vs 2 ohm or 4ohm? If I have stock electric probably should go with 2 or 4 ohm? Just trying to figure this all out. Thanks again.
The only benefit to wiring to a certain ohm load is to get more power from your amp, usually most amps do more power at 1 ohms than 2 ohms and so forth. So what ever amp you get you need to match your sub up with it, if you get a D1 sub (you can wire it to 0.5 or 2 ohms), if you get a D2 sub (you can wire it to 1 and 4 ohms) and if you get a D4 sub (you can wire it to 2 or 8 ohms). Go to www.the12volt.com and play with subwoofer wiring configuration.
Subwoofer Wiring Diagrams
RF Punch 500-2 is a good amp for it :D . Basically anything that will do the rated rms that is a reputable company. RF, Sundown, Kicker, etc. Just stay away from those $20 ebay pos amps lol.
Thanks Ulrisa. Argent I should be able to give you the 25% on Friday. Do you accept pay pal or what are your payment options. Also I will get the dimensions tomorrow and post them here. We got dumped on with snow today so didn't feel like going outside. Thanks again man. Really appreciate it.
Thanks,
Jeremy
Yea, Pay pal is perfect. Once I get the max dimensions I can get this design finished up and get building :)
Andrew
Thanks I will have the dimensions for you first thing tomorrow morning. I really appreciate this. If its not too much of a hassle when you finish the design could I possibly see a picture of it. That would be awesome.
Thanks,
Jeremy
Sure, I will do a google sketch up for it. It will be a 2D version as I'm still learning the ins and outs of the 3D aspect of it.
Andrew
My dimensions are as follows, I did them a little smaller than my max just for a little wiggle room. 31 width X 21 deep X 16 high. If you need to go deeper to get the cubic feet you can was just trying to reserve some trunk space.
Thanks again,
Jeremy
That should be more than enough for one 12. I will have something done up by tonight.
Andrew
x2, that is the dimensions of my current box for one 15".
Forgot if I mentioned I needed the sub rear firing. Thanks for helping me out. I really appreciate it.
Thanks,
Jeremy
Ok I have
H - 16.00 Inches
D - 18.50 Inches
L - 29.50 Inches
That gives
2.5 Cubes for the sub
.13 for sub disp
.089 for bracing
14.6 x 2.5 Inch port opening gives 36.25 sq inches of port.
Double Baffle, Flush Mount, and both sides indented .75 Inches, Dayton Audio Gold Plated Binding Post, black or charcoal carpet.
$180 Shipped to your door step.
Andrew
Ok I have
H - 16.00 Inches
D - 18.50 Inches
L - 31.00 Inches
That gives
.13 for sub disp
.089 for bracing
Andrew
That's awesome. Thanks so much pm your paypal info. I will give you the 45 dollar down payment tomorrow.
Thanks,
Jeremy
And to Argent Black carpet if you would. I have beige interior and think it would pop more with black carpet.
Edited by PhishHead
PhishHead please note the box is only 29.50 Inches in length instead of 31 Inches. I accidentally added something in there twice.
I have black carpet marked down :)
Cheers, Andrew
