Cinnabun187
Dual 15" BL Enclosure
I'm going atleast a 7cuft box tuned to somewhat 30-35hzt range. I'm building my own box and the subs aren't here yet. According to UPS the subs weigh in at 54lbs each. I'm simply asking if i should double baffle the box?
i would double baffle (or if you're using larger wood you can single baffle. for my bl i used 1inch) and also use allthread rods for support in the box, the BL's are pretty hefty woofers.
its never a bad idea to double baffle. especially with 108 pounds on the baffle.
i would most definitely do the double baffle.
OK Cool thanks man I could only find 3/4 inch MDF between Lowes and Home Depot. Where did you find 1" MDF?
double layered 1/2 or double 3/4 works too.
you can go to lumbar yards and buy 1 inch from there too.
1" is custom ordered around here.
Double it and brace it.
Think of it this way, you'll never regret having too much bracing unless, simply put, your stupid and lose too much airspace. But you'll really regret it when your baffle breaks cause you didn't brace it.
