sundownz
Z v.2 18 / 3 Spiders / NS Cone TS Specs
Built for a dealer... NS cone is standard on 18s.
They went with 3 spiders and dual leads as well.
Just a very short break-in period.
RE: 3.55 ohms
Fs: 35.5 Hz
Qes: 0.534
Qms: 7.341
Qts: 0.497
Le: 2.66 mH
Vas: 90.04 L
BL: 24.556 NA
Cms: 49.32 uM/N
Mms: 405 g
Sens: 90.6 dB 1w/1m
Yikes, that's alot of subwoofer. woot.gif I like it!
What a beast :santa: .
Will the fs on the new ns be higher, lower or the same as this example? Also, which way would you go Jacob if you wanted to buidla 49.9 bassracer, with 2 z 18 as above, or 2 new ns 18? Probably 4-6 k power total
NS v.2 will always have a lower FS with a given suspension as the coil is significantly heavier.
149.9 shouldn't be too hard for either two of these or two NS v.2 -- the NS v.2 is made to sustain more power, though.
Wow very impressive, I was doubtful when I saw the T/S of the other hybrid you built...let's just say my opinion changed :)
I will need the power handling, as it will be a daily system as well. Just waiting on the announcement for the ns v2 !
how could you doubt him in the first place? you build subs?
Fuck yes. I'm not stupid FYI, I know T/S parameters and what they mean.
ok bud,
Just built a "stock" unit with 2 spiders but otherwise the same as this one...
Fs drops to 30 Hz
Vas increases to 126 L
Qts drops to 0.45
This will be the normal configuration for 99% of people.
This is sexy shit man..............When is production slated to start?
It has started -- these are for customers.
We are just back logged because so many people ordered before they got here... I didn't run a pre-sale at all but alot of folks wanted to pre-pay anyway.
