pimpedout97x
IA6.4 Crossover question
On the IA6.4, if you leave the crossover selector to "full" does that mean you can set the low pass at a certain frequency, and the high pass at a certain frequency? or do the HPF and LPF adjusters not work when its set to play full range?
so example if i wanted a set of mids set to play 100hz to 5000hz, i could put the thing on full, then put the lpf to 100 and the hpf to 5k? (just an example)
Edited by pimpedout97x
No it doesnt work like that, full range means it will play full range. Set your amp to Low Pass Filter at 5,000Hz and your subsonic filter to 100Hz, this way they will play anything from 5,000hz down to 100hz.
He's brought it here before, but obviously needed a real answer. :)
VJ full means no crossover 99.999% of the time.
i thought it was black and white, and he knows i have 2 of them and only a fone call away
lol u kno i roll deep in IA ova here u text and aim me for way less imp shizz so why not this feg... ur still my boy tho
