flipzslick
Aero port help
seen this link on one of our other threads....
i would like to write down the basic formula mentioned in it for the aero ports.
referring to the port area equivalent of a slot port.
if i said that right.
it mentions that you can be safe with 56% of what a slot port needs for the area with an aero port.
is this a good rule of thumb to keep in mind?
aero port guide
so, i found this one too, and after playing around with the numbers a while, i seen that the 56% came up again, hmmm, might be on to something here.
these guys get a little deeper with it, but, in short, i think i got it.
lots of info though,
hope it helps.
chop
I can't link to the CA post for some reason, but I bet they are just misquoting Neil.
It isn't that you can use 56% of the area, but that the velocity is 56% less. (amusingly 6.67m/s is more than 56% less than 15m/s)
i could not link back to it from my link or the one under fabrication, where i got it from :shrug:
i find that within useing slot ports, i can get alot closer to the port area that i need / desire , than with the aero ports.
the velocity is 56% less, okay!
thanks
You can make an "aero" port out of a slot. Just requires some kerfs :)
i have never linked those two together.
you are 100% right. i see where you are coming from.
