one luv
1 15" FI BL fully loaded
I was really hoping some one could help me out with blueprints or a layout for the idea enclosuer for this sub int he space i have to work with. car is a 96 cadi fleetwood brougham rwd i measure it out and The max demensions are H 16 W 42 L 28,
i would like a box with 45's in it if possible. i only listen to bassy rap and r&b jezzy,gucci mane, etc for examples. ported obviously tuned to 32hz? again this if for a 15 FI BL fully loaded help woul dbe GREATLY appreciated.
If you want to and close to indiana i could sell you my box for a single 15
i got two now so i don't need it
its doesn't have 45s but i imagine you could pop the top off add them in and then just seal the top back on again
probably take some power to pop the top off the box too
im in omaha nebraska.. wonder what shipping would run? ahat size,cubes, tuning is the box? pics?
How about this:
~4 cuft net tuned to 32 Hz
16" h x 40" w x 20" d
Port is 14.5" x 4", 30" long. To get 30", you make the side port wall so it extends into the box until it is 4" from the back wall, then add a piece 10" long running parallel to the back wall.
Box is .75" thick, except the baffle is 1.5" thick.
Those dimensions allow for ~0.5 cuft to add 45's to the corners and bracing. If you don't use all of it, or you use a little more, it will still work great.
I live in omaha too. I'm sure shipping will be atleast $50. Are you looking at building your own or buying one?
How about this:
i can build or buy really doesnt make a differenc to me
I figured you were trying to save money and thats why you were looking for designs to build your own. I'm assuming you have all the tools and if you do I would highly suggest building it yourself. This should be a pretty easy box to build. I suggest you go to home depot and have them make all the cuts for you that they can. It makes it much easier on you especially if you dont have a table saw.
oh yeah,i have table saw, you name it i pretty much got it tool wise,lol yeah i was basically looking for demisions so i could build...
