JPagan1993
With the audiopipe being 2 ohm stable. How would you wire 2 dual 1's to a 2 ohm load mono or 1 ohm per channel parallel? You could do 2 ohms per channel on the audiopipe, but I think the sundown would put out more power at 1 ohm than the audiopipe wired at 2 ohms per channel. I would get the sundown and run it at 1 ohm.
This
