mustangsub
ported box for 15 " ascendant audio chaos
i wanted to know if i could make a ported box with a small trunk. the dimenions are 11 1/2 height, 15 depth, 46 length. thanks
Thats not a trunk. Sounds like a couple shoeboxes. If thats all the room you have, it will be tough.
x2, I would personally shoot for a 12" with that size trunk, plus it will leave you with some more room for other things
could i port the 12?
haha i know i hate it. and its a convertible so i cant put it in the back of the car
Why not?
You can port any size driver, I have seen a 6.5" driver ported before.
Why not?
i really dont know this is my first build
Why not?
You are going to want to port that if you want to be able to hear it in your convertible.
Why not?
sweet im prob gonna get a 12" earthquake subzero it has a mouting depth of about 7 1/2
Why not?
yea thats what ive heard
Why not?
do u have any guess on how big the box should be or rough dimensions
Why not?
It depends on big of a driver you will use, 12" or 15"? The same Choas series?
Why not?
12" and no i actually found a earthquake subzero sbwoofer for 200
Subzero Subwoofers this is a link of it. it has a mounting depth of 7 1/2
Why not?
Im not able to enter the subzero catagory. I cant see the specs.
Why not?
This is all i can find http://www.earthquakesound.com/IMAGEJP/CAR/pdf/subzero12manual.pdf
well lets say the chaos 12" for now
Edited by mustangsub
You can make it work but the enclosure will be very long to get the volume you need with the chaos.
any idea how long were talkin? cuz i got bout 47inches to work with
Try plugging in some numbers with this. RE calc. Its not going to be exact and it leaves out the driver displacement but it will give you a good idea of how large it needs to be. Its probably going to be over three feet long.
this is what i got. 35 width, 10 height, box top and bottom depth 14.5, .75 thickness, port height 8.5, port width 1.5, port lenght 12.25, port length 2: 10. the box volume was 1.94 and the frencecy was 25
You will have to flip flop some numbers to get them exactly right. 25hz sounds pretty low to me. A wider port is a good idea as well because 1.5" is a little slim also. I would go about 2-3" on the port width. The enclosure will look really funny and Im not even sure the shape is very optimal. Its possible but...
Have you ever thought about glassing to get maximum volume from your trunk?
what is glassing?
