jellyfish420
my active setup
would there be a noticable difference between 70wx2 passive on my RE 6.5's and 125x4 active thru my 860? i might be getting a visonik 4208. anyone used this amp? is it any good???
Im shure you would notice a difference in SQ.
I had/have MA amps (same as visonik) no problems at all with any of them
need an active x-over? i have one to maby sell
wouldn't i be able to run it 3-way off my 860?
the guy told me it was 125wx4 but i looked up the model # and it said 250x4 :D
supa...how much do you think a visonik 4channel amp would be worth. V4208
250x4@ 4ohm
360x4@ 2ohm
500x2@ 4ohm
Synergy, its in his pictures thread
250x4@ 4ohm
360x4@ 2ohm
500x2@ 4ohm
Should be around $180 or so for a new one.
i was running my ID chameleons passive, then switched to active on my 860 also. didnt notice too much of a difference but i only had it active for a week b4 i changed my setup. it's helping a lot more with my new setup.
the 860 has a lot different feel in promode, you'd be amazed. you think the 860 is decent now, it turns into a whole different deck in network mode. you get to control each source level, choose all your xover points (theres a lot more to pick from), choose the slopes (also a lot more to choose from), and control time alignment for every single source (6channel). i recommend you go active.
i was playing w/ it in pro mode for a little bit today. thats why i wanna do it. it looks like i would have ALOT more control over the sound.
supa he was wanting 190 shipped for it used...w/ no endcaps.
i think i might wait for a better deal, being thats more than they were new.....
no problem
its pretty much a HK-597 4ch
Ive seen them for $200 new on ebay
Model: HK-598
4 x 200W RMS @ 4 Ohm Stereo
4 x 400W RMS @ 2 Ohm Stereo
2 x 800W RMS @ 4 Ohm Mono
Dimensions (H x W x L): 2.7
still need a some what matching ma audio active x-over?
