freemanjc
Sundown Amp Choice
Friends.
I have ordered a FI Q12 (Dual 2 OHMS) single sub that will go into a ported sub-woofer enclosure just as soon as I can get in contact with pound that sound. First, I am trying to find out what's the difference between the following two amps, if there is any.
a. Sundown Audio SAZ-1000D = RMS 600 x 1 watts @ 2 ohms
b. Sundown Audio SAE-1200D = RMS 600 x 1 watts @ 2 ohms
Secondly, will either of these two be sufficient enough to power that particular sub since both are 2ohms x 1 600 RMS--------------------(underrated) ?
a.
SAZ series is the Competition line for Sundown.
SAZ offers an operating voltage of 10-16 volts, strapping capability, 24db per octave crossover, variable phase shift.
SAE line is the entry level line. Operating voltage of 12-14.4 volts, 12db per octave crossover. Switchable phase shift.
Both will power your woofer setup just fine.
Btw if you have 1 dual 2 ohm subwoofer it can be wired to either to a 4 ohm load or 1 ohm. Series will yield 4 ohm and Parallel will yield 1 ohm.
Btw if you have 1 dual 2 ohm sub woofer it can be wired to either to a 4 ohm load or 1 ohm. Series will yield 4 ohm and Parallel will yield 1 ohm.
Old School
Thank for the reply. Are these amps underrated? In regards to your post above are you saying I can hook my FI Q12 in a 1 ohm load or a 2 ohm load becuase my sub is Dual 2 Ohms. Forgive my ignorance, but I am new. Finally, is there any unique pro's and cons to either of them?
x2, you can wire your dual 2 ohm subwoofer in parallel to a 1 ohm load:
Go with the SAZ-1000D if money is not a concern.
You can wire a D2 sub to either 1 ohm or 4 ohms. I suggest you run a SAZ 1000 @ 1ohm to the Fi Q. Yes the Amp is under rated, with Good voltage, you should be able to get 1100-1300rms from the SAZ 1000.
All the information that he gave you are the pros and cons of each amplifier, both will do the job.
OldSkool_08, JPagan1993 and jay-cee.
You guys are awesome. I wish I had more knowledgeable people like you all working in my division. It would make my 9 month deployments so much easier. I take it it is safe to orders from Sound Solution Audio - Quality Subwoofers - Car Audio Forum - Car Stereo I hope they are in stock as I have ordered stuff before online to only be told they are not in stock but being advertised like they were. I will email them to check before I order. Once again thanks for the help in this matter?
r,
Freeway
r,
Freeway
Yes, SSA is very safe, always hear positive feedback from customers.
It is where I got my Sundown Amps from and where I will get my third one from. I ordered a Mach 5 Audio MLI-65 midbass speaker from these guys also and have not had any problems with them period.
Way to help him guys :drink40:
Go SSA Team!
Go SSA Team!
Well it appears that there is no place on earth that has the Sundown Audio SAZ-1000D in stock! So I might pull the trigger on the Sundown Audio SAE-1200D. I think I will be fine with this amp though!
Go SSA Team!
Yeah either amp will do the job so you cant go wrong with either purchase.
