sthib
what should i do?
im about to just sell em they not what i was looking for!
What are you about to sell, what about them arent you looking for?
Wait, the audioques? So are you using the SSDs?
if i can sell the audioques i will and do like a 3 12inch ssd setup in a mini blow through
Well let us know what you do; I'd be glad to help with that box too if you want...
yea i will im done with the audioques they are not what i expected i just dont know if i should keep the 2200d and do 2 12s are sell the 2200d and do 3 12s each with a zx750.1 on it.
Why the move to the small amp?
Still, kickers have a set subsonic filter so you gotta be careful how you tune the enclosure you put the subs in.
If you want more power or something, use that money to scoop up a sundown... Maybe a SAZ-2000D or a 3500 even if you feel like dropping the bucks to drop some serious bass-producing power in your ride.
the un even ohm load would burn the amp tho right? are i could run a sundown 2000 on just 2ssds
the un even ohm load would burn the amp tho right?...
No.
I don't know what ohm model you have for your ssds but I think you'd end up running them at 1.3 something if they are dual 1s... I'm probably wrong, but either way x2 uneven ohm load doesn't matter, you're not at always exactly 1 ohm or 2 ohms or whatever.
so your telling me that i could get 3 ssds on 1 1ohm amp and be safe and not blow the amp are speakers i was always told to run even loads.
People run 3 sub setups all the time, and you usually end up with an uneven load, (unless the speakers have a high enough impedence rating to start with), I think. Either way you should be good. What did you think was going to happen if you wired up those audioques? That would have been a funky load but it would have worked.
what you mean when i wired up the audioques?
I ran three kicker cvx's 12" subwoofers at 1.3333ohms with no problem just make sure your amp is one ohm stable.
I would get the dual 2 ohm version and wire them like this to get a 1.33333 ohm load:
OR
Get the dual 1 ohm version and wire them like this to get a 1.5 ohm load:
I was under the impression that you were already using them...
i was just didnt undersstand what you had meant.
