Julian
Wall design needed
I'm planning on building a wall in my Lumina, I'm in need of a design. My set up will consist of 1 DC power engineering 270 amp alternator,~3 deka intemidators, 2 Audioque HDC3 18's in a 12 Cuft wall with a removable port tuned to 38 for daily and higher for comp. Lastly to power the subs a Sundown Audio 3000d.
here are some specs with pictures included.
Pictures w/ measurements
Height: 37 in
Width: 29 in and at the curve 38 in
from the hump to the roof is 38 in
33 in from rear deck to seats
46 in from bottom of the floor to the ceiling
55 inch from door to door
More pictures
(P.S. I know my carpet is dirty. M5 already made it apparent)
Edited by Julian
PM Shizzzon. He does some great designs.
I spy KnuKonceptz Klarity RCA Kables, FTW! :peepwall: Any updates?
If you plan to compete then I'd do 20^2 of port area per cube and tune around 43-45Hz. Then make a port reducer to lower port area/tuning for daily. Port on driver's side. And get another 3000d.
I walled a 2003 Caddy last year for a team member, 2 DD9518's on 2 AQ3500's.
yea, i'd suggest more power too but it's his call.
I like to do 16sqin of port per cube for daily but comp use i go lots bigger!
I usually like to go for 24sqin per cube minimal and 32sqin per cube optimal.
I'm workin on his wall right now actually.
I might change it but as of right now, he might be gettin anywhere between 320-380sqin of port for comp use and ~200sqin for daily.
ok, here is design i came up with.
I haven't put the port length in there because i do nto know if u want to be able to manually tune this for competition or just have 2 preset ports made for this wall.
Let me know so i can finish that part.
as soon as i get another job im getting another saz-3000d :P.
1 dc 270 amp alt, 2 saz-3000d, ~3 dekas... should be fun
